P0300 Code
Old Feb 10, 2009 | 01:56 PM
fever42's Avatar
Default P0300 Code
For the last 3/4 weeks my car hasbeen doing the p0300 code thing, have replaced wires/plugs/icm. Local shop did this work and problem went away for a few 100 miles.
The last time it started doing this I turned off and restarted and while it started was running rough same as before only this time it was blowing white smoke out of exhaust pipes
is this a sign of my uim and or heads leaking water into cylinders, no water in oil and far as I can tell not low on water or oil in water. Any idears the shophas no idea
Old Feb 10, 2009 | 03:09 PM
kweef's Avatar
Default RE: P0300 Code
low on water? check ur coolant level
Old Feb 12, 2009 | 07:37 PM
biggriggs's Avatar
Real quick, I'd do a visual check of all of the vacuum lines running into the TB.
You should also be able to hear it whistling under the hood if it's a vacuum leak.
That would cause a rough idle and misfires, and it's real quick to check.
-Riggs.
04IntimidatorSS
Oct 15, 2016 09:02 PM
Chevy03
Jun 17, 2013 10:53 AM
silver86
Sep 4, 2010 11:45 PM
nitehawkjcb
Apr 13, 2010 11:49 PM
drayven
May 12, 2007 09:43 AM
