6th Gen ('00-'05): Overheating
Old Nov 14, 2017 | 09:42 AM
Pramey23's Avatar
Exclamation Overheating
Need help on my 2003 Monte Carlo 3.4 liter LS I have overheating problems we have replaced water pump thermostat sensors radiator checked all the hoses and it still overheating badly not sure what it could be
Old Nov 14, 2017 | 10:44 AM
It could be something very serious like an issue with a headgasket allowing air into the system. I would honestly get the engine tested for it. I dealt with overheating on an old 3100 for a long time, couldn't chase it down and it turned out to be the headgasket.
Old Nov 14, 2017 | 11:31 AM
ssintimidator3's Avatar
Did you check that you cooling fans are both operating?
Check the thermostat? ( If not a fail safe type, and stuck closed could be the problem )
Old Nov 14, 2017 | 12:51 PM
Pramey23's Avatar
Both fans are working and it is a fail safe type of t stat and the car won't stay cool enough to make it to anywhere to have the system tested we're stuck in a campground about 30 minutes from any town I've been doing the work from other people bringing me the parts and just doing it I think it could be the head gasket is there any way that I could diagnose it to be the head gasket without taking everything down and looking at the gaskets themselves
Old Nov 14, 2017 | 01:31 PM
