Overheating
Need help on my 2003 Monte Carlo 3.4 liter LS I have overheating problems we have replaced water pump thermostat sensors radiator checked all the hoses and it still overheating badly not sure what it could be
It could be something very serious like an issue with a headgasket allowing air into the system. I would honestly get the engine tested for it. I dealt with overheating on an old 3100 for a long time, couldn't chase it down and it turned out to be the headgasket.
Did you check that you cooling fans are both operating?
Check the thermostat? ( If not a fail safe type, and stuck closed could be the problem ) |
Both fans are working and it is a fail safe type of t stat and the car won't stay cool enough to make it to anywhere to have the system tested we're stuck in a campground about 30 minutes from any town I've been doing the work from other people bringing me the parts and just doing it I think it could be the head gasket is there any way that I could diagnose it to be the head gasket without taking everything down and looking at the gaskets themselves
This is a good read: Part 1 -How to do a Blown Head Gasket Test (GM 3.1L, 3.4L)
