is it ok to eliminate the thermostat for good
Old 03-23-2011 | 09:48 AM
zyon555's Avatar
Arrow is it ok to eliminate the thermostat for good
is it ok to take out the thermostat for good out of my 3800 monte carlo ss , or no and what happens if i do . please write back thanks.....
Old 03-23-2011 | 10:04 AM
MAMONTE's Avatar
NO!
You have to have a thermostat. Your car would never run at the proper operating tempeture, therefore would never run efficently.
Esecially in colder weather, your car would never warm up. You need to have a thermostat, if you are looking for cooler operating temps, then you can always get a 160 degree, or 180 degree thermo. They have drilled thermostats too.
Old 03-23-2011 | 10:05 AM
Why would you want to?
The car with no thermostat will take forever to warm up, and the PCM will go into failsafe mode
Old 03-23-2011 | 10:15 AM
I second and third the other comments about "NO".
1 - The car will never get to operating temp (matter of fact, my Monte threw a code once that is was not getting to operating temp fast enough, so I changed my T-stat).
2 - The vehicle is designed to run at specific temps.
3 - This could impact fuel economy negatively running too cold
4 - As stated earlier, if this is a daily driver, you will not have ANY heat during the winter.
I'm sure there are other reasons. Fair question to ask, but I hope you have your information. As stated earlier, you can try a T-stat that opens at a colder temp.
Old 03-23-2011 | 01:22 PM
dhelgie's Avatar
Besides the other great reasons mentioned above, here's an article (somewhat old) explaining how bad wear can be at lower oil temperatures.
HOTRODSRJ’s COOLING TIPS Operating temperature vs power and longevity!
Old 03-23-2011 | 05:07 PM
zyon555's Avatar
Ok i wont take it out , this big dummy i know told me to do it because he did his that way and he thinks it works fine for him, thats why i came to ask you pro's first because i wasn't buying the bs lol :0....
Old 03-24-2011 | 09:51 AM
Best thing you can do is educate yourself. There's a lot of good and bad info out there. It can take time to sift through and find the truth.
Old 03-24-2011 | 09:52 AM
TheMonteMan's Avatar
you can do it on older non computer controlled vehicles with out a problem. just not in winter time. ive done it before when ive had a thermostat go bad or stick. i cant speak for computer controlled stuff. im sure the above posts are correct.
Old 03-24-2011 | 03:44 PM
zyon555's Avatar
yeah , thanks a lot guys and this is why i love monte carlo forum everyone on here are very positive when it comes to the monte's thanks a lot .....
Old 03-24-2011 | 05:18 PM
Anytime!
