oil pressure problems
Old Mar 17, 2015 | 09:08 PM
jrok1310's Avatar
Default oil pressure problems
I was out driving just normal nothing aggresive or anything. Thats when i noticed the little screen on the cluster was saying i had low oil pressure. At that point the oil pressure gauge was bobbing back and forth over the half way mark. The engine temp was running normal and the oil isnt old enough it should have to be changed. What could be wrong and how would i go about fixing this problem? I have an 02 ss with roughly 200,000 on the engine.
Old Mar 17, 2015 | 11:09 PM
turbo monte's Avatar
either a bad sensor or the oil pump is going bad. either way until you get a way to monitor oil pressure dont drive the car because if you are losing oil pressure you will trash that engine very quick
Old Mar 18, 2015 | 06:14 AM
jrok1310's Avatar
Well the gauge is not reading that it is extremely low or high its just bobbing around a bit where it used to sit before the code came on the little message center
joe111599
Jun 10, 2016 07:01 PM
Randy Biron
Jul 14, 2012 08:07 PM
zyon555
Jun 18, 2011 11:47 PM
96_z34
May 17, 2006 10:45 PM
c1benny
Nov 10, 2005 12:06 PM
