Oil Capacity for 2006 3500 V6
Old Feb 23, 2008 | 09:54 PM
24_48Fan's Avatar
Default Oil Capacity for 2006 3500 V6
Is it 4 or 4.5 quarts? The owners manual says 4 quarts. I have seen on the web 4.5
The filter is being changed as well.
Old Feb 23, 2008 | 10:05 PM
RickCoMatic's Avatar
Default RE: Oil Capacity for 2006 3500 V6
Put the 4 Quarts in it.
Run-it and let it warm up while you leak-check the filter and drain plug.
Shut 'er down and pull the dipstick after the oil settles.
Read the dipstick and top-it-up to the Max line.
You'll be close to 4.5 Quarts once things get settled-down and you get the read off the dipstick.
Don't be surprised if you wind-up using almost the whole 5 Quarts.
It depends on how much is really in the containers and how much you drained-out!
Old Feb 23, 2008 | 10:23 PM
24_48Fan's Avatar
I put in 4 quarts and let it sit for 20 minutes after running, check the stick and its right at the full mark.
Jeff Osborne
Jun 19, 2014 08:40 PM
Carlo8686
Aug 6, 2013 09:48 PM
DRuben
May 6, 2011 08:24 PM
JaxJim
Dec 23, 2010 07:57 AM
East
Jan 21, 2010 12:44 PM
