Odd smell
Old Sep 28, 2012 | 09:56 PM
Mine does htat... emits a slight little cloudy haze too... it doesn't do it often but it will do it. I never have figured it out.
CHECK:
freon....also high humidity and running AC also causes slight haze... til humidity is reduced in the cabin...
Or possible coolant sepage....Does it smell like anti-freeze or oil Duane?
Old Sep 29, 2012 | 06:00 AM
Also probably unrelated, but you should check and replace your cabin air filter if you have never done so.
Old Sep 29, 2012 | 01:31 PM
02CHEVYMONTESS's Avatar
how do i check and replace cabin filter?
Old Sep 29, 2012 | 02:42 PM
Cowboy6622's Avatar
It's underneath the cowl on the passenger side. You haev to set your wipers up and turn the key off, then there are a few things you pop out, lift the cowl up, and there is your filter. I need to change mine. I haven't done that in a couple of years.
Mine does the hazy thing and smell when teh a/c compressor is on every once in a blue moon.
Old Sep 29, 2012 | 05:19 PM
ok i will do asap. but i get smell even when everything is off heat or a/c
Old Sep 30, 2012 | 02:19 PM
just changed my cabin filter so i will update on any smells if they are still there
Old Oct 3, 2012 | 08:22 AM
Sometimes bacteria can also build up in the cars vent system. A can of lysol sprayed into the cowl while the car is on max can help kill it
Old Oct 3, 2012 | 03:14 PM
just changed the cabin filter but havent driven long enough to see if that correct issue
shingding88
Jan 6, 2010 06:49 PM
knightfan26917
Dec 1, 2008 02:05 AM
jay26
Jun 18, 2007 09:44 PM
Nebraska2000ES
Dec 28, 2005 03:54 PM
SophicSage
Aug 3, 2005 12:08 AM
