Odd smell
Old Sep 28, 2012 | 06:20 PM
02CHEVYMONTESS's Avatar
Default Odd smell
I have a odd smell coming through vents after driving for 10-15 minutes. Kinda smells like a oil burn but im not sure. i have no other issues. 2002 Chevy SS . Any ideas?
Old Sep 28, 2012 | 06:27 PM
Maybe gasket leak?
Old Sep 28, 2012 | 07:02 PM
Is it oil or an antifreez smell?
Old Sep 28, 2012 | 07:07 PM
actually smell of oil from what i can tell
Old Sep 28, 2012 | 07:10 PM
Id check for oil leaks first thing than hopefully its somthing simple & easy
Old Sep 28, 2012 | 07:27 PM
How's your antifreeze level in radiator ? It could be your heater core leaking .
Old Sep 28, 2012 | 07:33 PM
It could be a valve cover gasket. They make a dye kit and light but i dont know that much about it. I think you put it in the oil and run the engine then look with the special light to see were any current leaks are.
Old Sep 28, 2012 | 07:40 PM
i will buy that kit and check all fluids again tomorrow and ill post update
Old Sep 28, 2012 | 09:06 PM
Cowboy6622's Avatar
Mine does htat... emits a slight little cloudy haze too... it doesn't do it often but it will do it. I never have figured it out.
Old Sep 28, 2012 | 09:08 PM
no cloudy haze yet but i am doina full fluid change in week or so , i will look close at stuff to find maybe a leak somewhere..ill post updates
