Odd AC "problem"
Old Jul 31, 2005 | 11:26 PM
SophicSage's Avatar
Default Odd AC "problem"
OK, I followed some advice from this forum a little while back....as far as recharging the system with R-134A. It worked fine and the car is cooling from all vents. There is something odd going on, however. Whenever I turn the car off, there is sort of a hissing sound coming from inside the dash somewhere. It's not really a hiss, either...it's almost like a gurgling sound that lasts about 5 seconds. This only started after I recharged the system. Also, the air won't cool right on the highest setting for the A/C when it's on MAX COOL. It's only cold when I set it to level 3 on MAX COOL or nomal A/C. Maybe I actually have a leak in the system? What do you all think about this?
Jon
PS: I have to say...I still like this car more than my 2003 Impala... : )
97 Monte LS
84.400 mi.
Old Aug 1, 2005 | 01:00 AM
04MonteLS's Avatar
Default RE: Odd AC "problem"
ORIGINAL: SophicSage
Jon
97 Monte LS
84.400 mi.
I don't really have any input on the AC problem, I just wanted to know why you like the 97 Monte over the 2003 Impala?
Old Aug 1, 2005 | 07:12 PM
Tribalwolf77's Avatar
I was told that the hissing is the refrigerant recirculating, and the gurgling is just moisture in the condensor. My A/C also makes those noises. When you say the air won't cool right what exactly do you mean? On the highest setting in my car I usually have to wait 10 minutes for the coldest air to come out, it's almost instantaneous on the other settings.
Old Aug 2, 2005 | 01:11 PM
montejass's Avatar
My A/C system both in my car and in my house makes that gurgle noise. I think it's pretty normal. If you loose freon again have your A/C guy run dye through the system to find the leak. Does it still seem that hot air is mixing with cool air? You may still have something going on with the blendoor. Maybe a vac leak somewhere.
My opinion on the Impala is: I don't care for them at all. I actually test drove one the day I purchased my Monte. As MonteLS would say, it's fugly..lol
Old Aug 2, 2005 | 04:14 PM
04MonteLS's Avatar
ORIGINAL: montejass
[sm=exactly.gif]
Old Aug 3, 2005 | 12:08 AM
SophicSage's Avatar
ORIGINAL: 04MonteLS
Jon
97 Monte LS
84.400 mi.
Well, I like the 97 Monte because of the way the seating conforms with my duty belt on the way to work. It just seems like the seats mold around me much better than the Impala.
bc1025
Apr 20, 2013 09:13 PM
Pure2sin
Aug 9, 2010 11:15 PM
knightfan26917
Dec 1, 2008 02:05 AM
jay26
Jun 18, 2007 09:44 PM
Nebraska2000ES
Dec 28, 2005 03:54 PM
