normal for an 03 monte?
Old Sep 21, 2010 | 04:43 PM
cjbots's Avatar
Default normal for an 03 monte?
Hello.
If you didnt know the day after I bought my car the engine blew. so now I am a bit paranoid. ( watching my gauges and such ) I have owned cars before but this is my first Chevy. I noticed when I am sitting at a red light my oil pressure goes a bit below half, but when I am moving it goes to about 3/4s. I dont know if this is normal or not for montes to do this. my other cars in the past have not done this..
thanks for your input!
Old Sep 21, 2010 | 07:37 PM
sideways's Avatar
Normal, mine acts exactly the same.
Old Sep 21, 2010 | 08:03 PM
Norris15's Avatar
its normal but if you get suspicious just check your oil
Old Sep 21, 2010 | 10:55 PM
zipper's Avatar
Is your Monte an LS or an SS just out of curiousity? It sounds like someone dumped a poorly maintained car on you if it blew the engine the day after you bought it.
Old Sep 21, 2010 | 11:19 PM
nitehawkjcb's Avatar
As long as you use the correct viscosity oil, your oil pressure should be fine.
Old Sep 21, 2010 | 11:43 PM
jaws2008's Avatar
GOT SPL
Yes as soon as you hit the gas even slightly the oil pressure gauge goes up. Its normal.
Old Sep 21, 2010 | 11:53 PM
Sucks about the engine blowing up the day after you got it. I would say it's normal for the pressure to drop when the engine is not under load. as long as it's not dropping to nothing there should be no problem.
Old Sep 24, 2010 | 10:33 PM
jcoeracing97's Avatar
I use Quaker State 10W30 Full Synthetic H/P in my '03 SS with a Wix oil filter. The car has 172,000 miles on it and holds steady pressure at idle and increases slightly under throttle. Perfectly normal condition your'e experiencing.
GrandPaDave
Apr 20, 2007 05:11 AM
TrapShooter8
Apr 4, 2007 10:24 PM
buka
Jul 11, 2006 03:11 AM
01whitess
May 5, 2006 12:27 AM
04MonteLS
May 31, 2005 03:40 AM
