no overdrive
Old Sep 7, 2013 | 09:41 PM
the reaper's Avatar
Default no overdrive
96 Monte Carlo 3.1 transmission was shifting fine then got up to go to work and no overdrive. I changed the fluid and filter nothing changed. Can someone please help?
Old Sep 7, 2013 | 10:10 PM
Welcome to the forum.
Thanks for Joining the MCF Family
Is the trans full? ... Is it overfull?
How many miles are on it? Most timesthese trans hit around 80,000 + miles
and trans issues start to show up....It could also be something as simple as a shift solenoid.
Maybe some one else will chime in with more ideas/suggestions...
the reaper's Avatar
When I'm on the highway doing 60 my rpms are at around 4000
Old Sep 7, 2013 | 10:14 PM
the reaper's Avatar
Just under 160000 fluid is full did see some shavings in the pan and tiny chunks not just real fine metal
Old Sep 7, 2013 | 10:18 PM
How long ago did u do the fluid filter change? (what mileage?)
But with 160,000 + miles on it....
My best guess..... Its time to get it rebuilt....
Old Sep 7, 2013 | 10:20 PM
the reaper's Avatar
Just got the car a month ago been driving fine until this and changed the filter this past friday
Old Sep 7, 2013 | 10:28 PM
Maybe try pulling the pan... Change out the solenoid?.... If that doesn't help..
Then I would recommend a soft rebuild..... or get a used trans....and hope its better than the one you have?
Old Sep 7, 2013 | 10:31 PM
the reaper's Avatar
If the tranny is bad how long would it take to swap it out? I do have experience and I have swapped fwd trans before just not in one of these Monte carlos
Old Sep 9, 2013 | 11:32 AM
the reaper's Avatar
Another thing when I'm on the interstate and my rpms are at around 4g I let off the gas my rpms go down to idle then I press the gas to speed up it doesn't catch until I'm back up to 4gs and it does that in all gears like it is slipping I guess
Old Sep 17, 2013 | 06:00 AM
dbarn's Avatar
Had the same issue with my '01. Splines on the OD shaft were gone so it couldn't lock into OD. Replaced it and it's back to around 2,000 rpm's at 70mph.
Drifter
Sep 29, 2009 08:27 AM
vincenti
Jun 5, 2009 09:11 PM
24_48Fan
Apr 11, 2009 04:08 AM
mrl390
Oct 10, 2008 07:11 PM
bigmichaelcool
Feb 12, 2008 07:25 AM
