New guy here....need help with 1985 monte carlo engine swap
Hi everyone, I hope Im posting correctly here.My friend has a 1985 Monte Carlo. He put a 1964 Nova 383 stroker in MC.383 had standard transmission in Nova.MC already has Turbo 350 in it, so we installed engine and connected everything we could.Except for 2 problems.1st prob is starter.He has a high torque starter but we cant get it to work with 383/t350 transmission.We cant get it to "shim" where it will work.Its as if theres not enough clearance "sideways" to make it work.What type starter should he get? 2nd prob is water pump/alternator/power steering pump......Cant get all three to work out on it.Everything is on opposite sides from these 2 engines/cars...Can anyone steer us in direction to solve these probs?
Hi New Member DeCard & Welcome to the Monte Carlo Family...
I hope one of our 4th Gen Expert Member's reads your post 2day & will be able to assist in your problem on the install...
I attempted to find a answer doing a Web search, but did not find the answers you need.
Check back to see if anyone of our member's can assist...
Good Luck 4 Sure...
Good Luck 4 Sure...
