need help with a super charger
Old Feb 1, 2011 | 01:36 PM
Enzo354's Avatar
STILL SLOW
Mines still in progess. I started in august. Do a l32 swap.
Old Feb 1, 2011 | 09:13 PM
mk_douglas's Avatar
Wow thank you very much to all for the information and input into my problem so in the end it looks like it can be done special thanks to zipper with all that great info can zipper give me a rough cost on what this job is going to cost me? thanks again I will now have to decide if it is worth it.
Old Feb 1, 2011 | 09:44 PM
Enzo354's Avatar
STILL SLOW
You can probably do it for under 1k, but budget for 1500. I still suggest an engine swap. Much easier.
Old Feb 1, 2011 | 09:49 PM
zipper's Avatar
The general rule of thumb is to budget $1000 for a top swap. It's not that it will be that expensive because you can find top swaps here or on clubgp or other 3800 oriented forums for as cheap as $250. But you will need a lot of misc stuff that will nickel and dime you for quite a bit.
Also, talk to Enzo about actually doing the swap so that you can understand what some problems that come up while doing the top swap. I've never done a top swap, but I have changed the head gaskets on my Monte and that's about 85% of the work of a top swap. So I understand it, but I don't have personal experience with it. PacerSS might be able to help you too with the details of it.
I didn't mean to contradict you Enzo. $1500 would be a great budget and you would absolutely not go over that. An engine swap could be done cheaper depending on the price of the engine that you buy. Either way, it takes work to make hp, but it's worth it.
Old Feb 2, 2011 | 07:56 PM
mk_douglas's Avatar
Enzo so you are referring to a whole engine swap? I already have the supercharger and I have a good engine now so with that said I can still do it but change out some parts right?
Old Feb 6, 2011 | 10:49 PM
biggriggs's Avatar
You'll need a bit more than the supercharger. You'll need everything from the heads on up, as well as a few other odds and ends, including a pcm set up for the top swap or someone to tune your pcm for you.
Look around on here for threads about "top swaps", this topic has been discussed in detail many times.
Old Feb 14, 2011 | 12:46 AM
blasto172's Avatar
Also check out zz performance; They have a lot of info on doing a top swap, lists of needed parts, and install kits. They also sell a modified intake that lets you use the stock l36 head, and larger s/c pullies if you don't/can't do kr mods. Though you should also decide what your power goals are, after a while your better off going with a turbo kit than a top swap.
clmc1970
Dec 6, 2014 05:57 AM
02 Earnhardt Monte Carlo SS
39
Nov 17, 2014 06:16 AM
Aug 27, 2014 05:44 AM
midnightriderDC
24
Jan 3, 2012 07:05 PM
Dillon
Nov 16, 2006 04:51 AM
