Need Help Replacing Tentioner Pulley
Old Jul 13, 2008 | 02:12 PM
monte4me's Avatar
Default Need Help Replacing Tentioner Pulley
Hello All,
I have a 2002 Monte Carlo LS with the 3400 v6.
I have the classic issue of a bad tensioner pulley. I haven't worked much on these motors before, and am baffeled out how to remove the tensionor pulley. The only bolt head that is exposed is the one at the base of the tensioner arm. Do I need to remove this bolt and the arm all together? It appears that the bolt that holds the pulley on is on the block side, so it isn't accessible w/out removing the arm.
Has anyone replaced the tensioner pulley before? Please help.
Thanks
Shannon
Old Jul 13, 2008 | 03:43 PM
scc24540's Avatar
Default RE: Need Help Replacing Tentioner Pulley
just take that 1 bolt off and the whole assy. comes off. then reinstall the new one using the reverse
Old Jul 18, 2008 | 12:24 AM
z34phoenix's Avatar
yes at the pivot of the tensioner there is a bolt holding it on... remove that .... you can swap just the pulley but for the price diff its best to replace the entire thing. as sometimes the arm can snap!
carlo1
Nov 24, 2011 11:01 PM
malletboy
Oct 9, 2010 12:13 PM
monte07
Aug 9, 2010 04:26 PM
Steven73
Mar 9, 2010 10:04 PM
trevor c
Feb 15, 2010 05:47 PM
