Pulley Puller HELP
Old Mar 8, 2010 | 10:49 PM
Steven73's Avatar
Default Pulley Puller HELP
Well Im ready to Oreder MY 3.5 Pully. (Was thinking 3.4 but not riskin it.)
Modes are = zzp 2'5" DP catless/Cai/180stat/zzpfuel filter/altBoost
(Spark plugs i Just changed them to ac delcol platnium 1k ago AND WHAT A BITCH soo ill change those later...)
Im purchasing the zzp PCM with the 3.5 pully. Within the next month/2
Would anyone here have a zzp pulley puller I could Use? ill pay shipping.. And how does the pulley puller PRESS on the Modular pully system? I dont want to buy a pulley puller im only going to use once do I need ZZP MPS backing plate?
After my pulley drop my modes are done to the engine.
thank you
steve
Old Mar 9, 2010 | 12:14 AM
Have you scanned for KR yet? I'd say at least 75% chance you won't be able to run a 3.5" knock free. I'd bet you'll need some 1.9 rockers, a plog, or some headers to get rid of all the knock- you really only have 2 knock killing mods right now- the CAI and DP- but usually those barely get rid of the knock the cars have from the factory.
Secondly, a zzp pcm isn't going to let you run a 3.4" if you have any knock on the 3.5" (which I bet you will).
I'd definitely consider sticking some copper autolites in place of those platinum plugs too.
The ZZP MPS backing plate is only for removing the MPS, the zzp puller will install the modular pulley just fine.
You do know that you can rent a puller from zzp right?
Old Mar 9, 2010 | 07:59 AM
x2 I don't think you are ready for the pulley swap yet.
Old Mar 9, 2010 | 08:09 PM
Steven73's Avatar
"" Secondly, a zzp pcm isn't going to let you run a 3.4" if you have any knock on the 3.5" (which I bet you will).""
Sorry I did not mean the ZZP PCM was gonna Help me with a smaller Pully. I was going to Buy the PCM for the TUNE.. And since I was buying the pcm, Though I would buy Evrything I need for Pully Drop. (did not see zzp rents. Tool. But still Puttin the 100 down better of buying it) I Looked More into the 3.4 and yea BAD IDEA..
I am Gonna scan for knock, Was looking at the Aeroforce Intercepter scan gauge from zzp Also..
sorry EDITED MY FIRST POST
"Im purchasing the zzp PCM with the 3.4 pully. Within the next month/2"
I ment 3.5
I Had A email from ZZP and They Said I should Be fine with a 3.5 and Also told me to scan for knock. they also stated for 3.4 need (plog,heads,rockers)
anymore infor would be great thanks.
Old Mar 9, 2010 | 10:04 PM
Then I'd order the pcm and aeroforce first. Drive around to let the new pcm learn the fueling, and check your scan gauge. Make sure you have no KR, then pick up the 3.5" if you're all clear.
I do have a zzp pulley tool, but unfortunately its back in indiana in the storage unit waiting for me to get a house out here. There aren't a ton of L67 people on here- if you don't get a response for a puller- then maybe try posting on clubgp. You may still have to give them a chunk of money up front to cover in case you don't send it back, or break it- you know? Thats why zzp does it anyways.
ExplosiveSoundz
13
Mar 16, 2013 06:22 PM
ExplosiveSoundz
Oct 23, 2007 04:18 PM
2002covtz28
Oct 3, 2007 11:13 PM
wiz kidd
Mar 15, 2007 10:37 AM
