Need help removing oil pump drive!
Old Aug 17, 2007 | 02:00 PM
jcobz28's Avatar
Default Need help removing oil pump drive!
Motor is all apart, heads and all. Fixing a LIM and head gasket problem. While I'm here, I want to change the O-ring on the oil pump drive. I took out the 15mm bolt on the retainer, but the drive won't pull straight up like the Chiltons manual says it should. It spins in circles very freely, but there is ZERO up and down play. I got a pair of vice grips clamped on it real hard, and even with those pulling straight up I get nothing.
Am I missing something? Is there atrick or special tool needed for this???
It's a 3100 '98 Monte Carlo.
Thanks!
~Jacob
Old Aug 17, 2007 | 02:14 PM
jcobz28's Avatar
Default RE: Need help removing oil pump drive!
Never mind, I got it. If anybody else ever runs into this problem, just give it a few light taps with a metal hammer and it will loosen up a bit. Keep pulling upwards with some vice grips, rotate it, more taps with the hammer, rotate, pull up, and keep repeating until it "breaks loose" and slides straight up.
Old Aug 17, 2007 | 03:03 PM
04 Intimidator's Avatar
Is the darn thing press fitted?!?!?!
Old Aug 17, 2007 | 06:19 PM
jcobz28's Avatar
No, it's not press fitted. I think it was hard to pull because the O-ring was hardened. When I tried to pull it off the drive shaft, it just broke apart it was so hard a brittle.
Old Aug 17, 2007 | 07:03 PM
Ok, that makes sense. I couldn't see it being press fitted but a new "engineering" design wouldn't suprise me.
Old Aug 17, 2007 | 08:25 PM
HyperFox's Avatar
Lol.. New enginnering.. 2007 model hammer? lol
jim1405
Apr 21, 2014 10:32 AM
crete
Nov 6, 2011 07:05 PM
chevyman75
Nov 16, 2010 01:21 PM
dabeav3
Dec 11, 2007 09:43 AM
