3.4 DOHC Oil Pump Drive Leak
Old Dec 3, 2007 | 12:50 AM
dabeav3's Avatar
Default 3.4 DOHC Oil Pump Drive Leak
Had the typical oil leak from the oil pump drive shaft. Took the air cleaner assembly and exhaust crossover pipe off as well as the drive hold down. Lifted the drive up and slipped an o-ring in between it and the block. Tightened the hold down and put everything back together with no leaks. Much, much easier than removing the intake and/or the head to silicone orreplace the internal o-ring.
Old Dec 6, 2007 | 10:11 AM
smolek37k's Avatar
Default RE: 3.4 DOHC Oil Pump Drive Leak
do you have any pics?
Old Dec 10, 2007 | 07:09 AM
dabeav3's Avatar
Sorry, barely enough room to work let alone take pictures.
Old Dec 10, 2007 | 07:12 AM
wiz kidd's Avatar
wow, i dont hear about too many monte's having oil leaks, thats the first for me anyway...i've heard of intake manifolds going and the oil leaking into the antifreeze, or the other way around, but never seen anyone have to change the seal on the oil pump shaft
bet ya that took a lot of time
Old Dec 11, 2007 | 04:21 AM
dabeav3's Avatar
Unfortunately with the 3.4 DOHC (and I believe the other 2.8L based engines), the oil pump drive leakage problem is QUITE common. Fixing it is not a big deal but access is something else.
Old Dec 11, 2007 | 09:43 AM
z34phoenix's Avatar
yes it is a common issue with the DOHC. im sure many DOHC's ended their life on the road premeturely due to the owners giving up in dealing with this issue. GM calls for the rear head to be removed to properly fix it. that entails much more work then any push rod motor... consider removing and replaceing the Timing belt is part of pulling the rear head.... and GM charges 1200 for that. imagen the cost of the repair to replace a tiny rubber o ring!
jim1405
Apr 21, 2014 10:32 AM
greg
Aug 7, 2010 09:05 AM
greg
Aug 5, 2010 04:48 PM
dabeav3
Jul 1, 2008 06:40 AM
jcobz28
Aug 17, 2007 08:25 PM
