My supercharger is leaking a sh!t ton of oil?
Old Sep 12, 2012 | 07:27 PM
Dale_Jr_123's Avatar
Default My supercharger is leaking a **** ton of oil?
So my car has stunk and been smoking for 2 days now and i just looked at my motor and there is oil all around where the nose to the supercharger is located?!?!?!? The problem is i'm about 10 mins away from my home! can i drive it home is it safe?!?!?!? I can either take all backrounds and just take her slow or go all highway and take her 55mph. Please help me thank you!
Old Sep 12, 2012 | 07:33 PM
If it was my Monte , I would take the supercharger belt off an drive home.
Old Sep 12, 2012 | 07:39 PM
how do you take the supercharger belt off? It's dark outside!
Old Sep 12, 2012 | 08:39 PM
nitehawkjcb's Avatar
You grab a ratchet and a 15 mm socket and put it on the tensioner, then remove the belt.
Is it leaking near the pulley? If so, you probably need to replace the snout seal.
80joe
Mar 2, 2011 08:20 PM
Chevycarlo97
May 25, 2009 04:30 PM
mattilus2121
Apr 16, 2009 03:52 PM
mattilus2121
Mar 31, 2009 02:45 PM
Phils01Monte
Mar 30, 2008 07:26 PM
