My monte is dead :(
Old Aug 26, 2012 | 10:49 AM
  #471
inside where mike?
I think he means inside your house like you did with engine..
Old Aug 27, 2012 | 07:06 AM
  #472
Franks 03SS's Avatar
2011 Monte Of The Year
ohh geez
Old Aug 27, 2012 | 07:51 AM
  #473
Ok so I ran into some minor issues yesterday..
Since the UIM neck is much longer than the L36 one, I already knew the Throttle and cruise cables were going to sit back farther and at a narrower turn. So I released the Cables from this bracket that holds them in place, it definitely released a lot of stress that was on them lol so that was that
Look at how Bunched up everything is in this area i installed one of the upper mounts so the motor is already sitting at the position it's supposed to be in. I'm going to have to do a little trimming on the TB cable bracket so it's not rubbing on the brake lines, once I get my alum. radiator mounts finished up, the 1/4 that moves the motor forward should help out a little as well I'm not too worried about engine movement either since I have the solid lower mounts on there
Btw, the TB in this pic is wide open that's why the cruise cable is sitting like that. I was testing it to see if it fully open and funtioned properly with the pedal to the floor oh and all the connections for the sensors reach just fine too so no need extend any wires
This is with the intake tube on the TB, no rubbing issues here but its pretty damn close to everything Haha also, im not sure how the filter is going to sit with the heat shield and all. If I run into a problem then I'll probably just go ahead and get some intake duct from ZZP
There really isn't much left to do but this rain isn't allowing me to get anything done and I go in for work at 3 so that sucks lol I already put in the new radiator and fans, along with new upper and lower hoses. Man the clamp on water pump hose is a pain to get on!! I still have the axels to pop back in the trans and getting the front suspension back in order, bleeding the brakes, filling the motor and trans with oil, and filling with coolant.... easy stuff I think that's about it, besides the TB issue lol but that's also easy
I'll keep you guys updated
Old Aug 27, 2012 | 08:05 AM
  #474
Weather for Lakeland, FL
<TABLE style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 4px" cellSpacing=0><TBODY><TR><TD style="PADDING-RIGHT: 10px" rowSpan=5><TD style="PADDING-RIGHT: 15px; WHITE-SPACE: nowrap; FONT-SIZE: 140%; VERTICAL-ALIGN: top; FONT-WEIGHT: bold" rowSpan=2>75°F | °C<TD style="BORDER-LEFT: rgb(216,216,216) 1px solid; WIDTH: 5px" rowSpan=5><TD style="VERTICAL-ALIGN: top" colSpan=2 align=center>Mon<TD style="VERTICAL-ALIGN: top" colSpan=2 align=center>Tue<TD style="VERTICAL-ALIGN: top" colSpan=2 align=center>Wed<TD style="VERTICAL-ALIGN: top" colSpan=2 align=center>Thu<TR><TD style="TEXT-ALIGN: center" rowSpan=3 colSpan=2><TD style="TEXT-ALIGN: center" rowSpan=3 colSpan=2><TD style="TEXT-ALIGN: center" rowSpan=3 colSpan=2><TD style="TEXT-ALIGN: center" rowSpan=3 colSpan=2><TR><TD style="PADDING-RIGHT: 15px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102)">Rain<TD><TD><TD><TR><TD style="PADDING-RIGHT: 15px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102)">Wind: E at 16 mph<TD><TD><TD><TR><TD style="PADDING-RIGHT: 15px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102); VERTICAL-ALIGN: top">Humidity: 100%<TD style="TEXT-ALIGN: right; PADDING-LEFT: 5px; PADDING-RIGHT: 2px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top">90°<TD style="TEXT-ALIGN: left; PADDING-LEFT: 2px; PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102); VERTICAL-ALIGN: top">73°<TD style="TEXT-ALIGN: right; PADDING-LEFT: 5px; PADDING-RIGHT: 2px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top">91°<TD style="TEXT-ALIGN: left; PADDING-LEFT: 2px; PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102); VERTICAL-ALIGN: top">73°<TD style="TEXT-ALIGN: right; PADDING-LEFT: 5px; PADDING-RIGHT: 2px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top">91°<TD style="TEXT-ALIGN: left; PADDING-LEFT: 2px; PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102); VERTICAL-ALIGN: top">73°<TD style="TEXT-ALIGN: right; PADDING-LEFT: 5px; PADDING-RIGHT: 2px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top">93°<TD style="TEXT-ALIGN: left; PADDING-LEFT: 2px; PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; COLOR: rgb(102,102,102); VERTICAL-ALIGN: top">72°</TD></TR></TBODY></TABLE>
Hi `Frank, I checked your weather today & it's not good
Mother Nature is making it difficult 4 U 4-Sure...Wish you Sunshine & a break from all your work...Good Luck & thanks for posting/sharing your rebuild...
Hopefully it clears later 2day & have periods of no rain after this afternoon.
Old Aug 27, 2012 | 08:40 AM
  #475
Thanks space well it stopped raining, it should clear out throughout the day though
Old Aug 27, 2012 | 06:47 PM
  #476
Pretty much done
Painted my calipers so I didn't get a chance to get the axels back on before i came to work lol
Really tight fit haha
It'll work for now till I get a nice CAI
My custom serpentine belt
You can also see the alum. coolant elbow...
Old Aug 27, 2012 | 07:04 PM
  #477
Did you fire it up
I know the axle isn't on... but... still...
Old Aug 27, 2012 | 08:58 PM
  #478
Frank, she is a thing of beauty!!! But seriously, I know Chibi and I are going nuts, fire it up lol!!
Old Aug 28, 2012 | 07:59 AM
  #479
Did you fire it up
Lol I want to get everything back together first
I'm actually kinda nervous to fire it up!
Old Aug 28, 2012 | 08:11 AM
  #480
</SPAN>OTE=Franks 03SS;490538]Lol I want to get everything back together first
I'm actually kinda nervous to fire it up! [/QUOTE]
Don't worry `Frank, Everything is going to be fine & it will be better then `new with more power + Just remember who did all that hard work & not 2 many member's could `do what you have done in their driveway & living room 4-Sure Just put in the key & fire her `up...You might have to make a few adjustments, but remember it was rebuilt by
LakeLand's PeformanceMan `Frank WoW `Wee's
I think you did a SuperSuper `Job ^
WoW, I don't know `if I can handle all this new POWER
"Frank, please slow down, I'd do anything `if you
slow down your new Monte Carlo Please (LOL)
Wish you the best of Luck on getting it fired `up & on
your highways of life...We are looking forward to your update...GOOOOOOOD LUCK 4-Sure
It was dead, and now it came back to Life
WoW Wee's `Frank...It's a Miracle
^Great `job `Frank
please, Please, PLEASE
(Take me 4 a ride will`ya) LOL
