My monte is dead :(
Old Aug 10, 2012 | 10:29 AM
  #321
Franks 03SS's Avatar
2011 Monte Of The Year
Originally Posted by Budsjlm
Do it, extra insurance they won't ever loosen up and back out, if the are like 3.1/3.r they are tourq to spec and done no lash adjustment but I do suggest having the heads on so you won't have to try to line pushrods and all that has up while going to tourq the head down
thanks man, the heads are already torqued down
I did not thread lock mine.
i'll just apply a little bit thanks mike
Old Aug 10, 2012 | 11:21 AM
  #322
Budsjlm's Avatar
good to hear, guess i missed that part
Old Aug 10, 2012 | 02:03 PM
  #323
Just did it today that's why haha
I'll update with some stuff on my break i just got to work right now lol
Old Aug 10, 2012 | 11:04 PM
  #324
Heads and rockers on the motor, all torqued down
My handy dandy angle meter i used haha
and I just ended up using my HB torque wrench
Went ahead and got the fitting on the TB, it's going to work PERFECTLY!! thats if I have enough clearance once installed! Lol
While I was drilling the hole, the drill bit caught the edge of the port on the inside of the TB and cracked the outside lip of the TB port I was able to get some good threads with the tap though, more than half of the fitting is screwed in, in this pic. Nothing a little JB weld can't fix that'll be one of last things I do though
Cleaned up blocked coolant ports on LIM
And my awesome porting on the coolant bypass lol
Old Aug 10, 2012 | 11:23 PM
  #325
JB Weld can sometimes be a metal worker's eraser lol!! Minor mistakes, EASILY corrected. But I still like the road that's taking. That was a BRILLIANT thought (more brilliant if everything will clear).
That will work PERFECTLY!! Some may think it's overkill, but I think it's JUST what the LIM needed
All very nice Frank!
Old Aug 11, 2012 | 07:15 AM
  #326
Thanks Jason After I JB weld it, I'll be painting it silver like my UIM
I did take quite a bit off haha, should've got a before pic
Old Aug 11, 2012 | 10:14 PM
  #327
Mike 00LS's Avatar
Damn Frank, looks like a brand new motor.
Old Aug 12, 2012 | 08:10 AM
  #328
Haha I wish mike thanks though
Old Aug 12, 2012 | 08:19 AM
  #329
Got my LIM torqued down yesterday, idk if I updated you guys on this but I ported my TB outlet, somewhat.... Lol about a week ago. Just to match a little better with the ZZP adapter lol
Before:
After: Not pretty but ehh haha
Also got my ISS lube kit and Stock Pcv tube in the mail yestersay
The tube was only $4.44 from GM so I figured what the heck haha
I mostly got it for the connection elbow that goes on the UIM port, just to have a factory look
Old Aug 12, 2012 | 09:36 AM
  #330
I have another question.... What do I use for a gasket where the ZZP adapter meets the UIM?? could I just use RTV or do I make my own gasket?
