my cylinder compression is low , what you think could be??
Old Apr 21, 2011 | 04:07 PM
78montecarlo's Avatar
Default my cylinder compression is low , what you think could be??
I was cheking the compression on the cylinders and a few ones are only putting 30 pds , the car runs good no shake , no weird sound, drive like a dream . You think could be the head gaskets ???
P.s the car is not overheating
Old Apr 21, 2011 | 05:36 PM
Budsjlm's Avatar
are you losing coolant? does your oil look like a chocolate milk shake? how many miles are on your car? what where the others putting out? most usefull is if you could give us what # cyl it is and what the pressure, did you do it on a cold engine or warm?
it could be a number of things,
try putting some oil in the cyl that gave you low #'s and try it again, if they are better your rings are toast
Old Apr 21, 2011 | 09:55 PM
the car was warm, and was the second cyl on the left side . In the first crank compression was only 30 pds
car got 50,000 miles or 150,000 not sure ,oil is looking good . and the other cyl was putting 80 pds
Old Apr 21, 2011 | 10:06 PM
Budsjlm's Avatar
You should crank the engine until the guage reading stops climbing. An engine in good shape usually takes 3-4 compression strokes to max out. The trick is to set the guage up so you can see it while cranking each time.
Old Apr 21, 2011 | 10:14 PM
I going to try that tomorrow, I was thinking if I have to rebuilt the engine ,I just gonna go head and do a swap for a 454 engine . let see what happen .
Thanks you for the time
Old Apr 22, 2011 | 10:19 AM
Budsjlm's Avatar
if you do that plan on getting a good amount of suspention parts, a 454 is ALOT heavier than a 305 they wern't built for a 454's weight
my budy had the hochtkis hit in his car and that if you put a bigblock in it recomends aluminum heads and intake to take a good amount of weight out
Hotchkis 89009K Hotchkis TVS Suspension Systems
also might want to think about getting a trans
05montecarloyo
Aug 8, 2012 07:02 PM
jasonsmith
Nov 15, 2011 11:36 AM
bryns96z34
Nov 21, 2009 07:49 PM
Phenomenon
Sep 3, 2008 08:06 PM
