my cylinder compression is low , what you think could be??
I was cheking the compression on the cylinders and a few ones are only putting 30 pds , the car runs good no shake , no weird sound, drive like a dream . You think could be the head gaskets ???
P.s the car is not overheating |
are you losing coolant? does your oil look like a chocolate milk shake? how many miles are on your car? what where the others putting out? most usefull is if you could give us what # cyl it is and what the pressure, did you do it on a cold engine or warm?
it could be a number of things, try putting some oil in the cyl that gave you low #'s and try it again, if they are better your rings are toast |
Originally Posted by Budsjlm
(Post 318068)
it could be a number of things, try putting some oil in the cyl that gave you low #'s and try it again, if they are better your rings are toast car got 50,000 miles or 150,000 not sure ,oil is looking good . and the other cyl was putting 80 pds |
You should crank the engine until the guage reading stops climbing. An engine in good shape usually takes 3-4 compression strokes to max out. The trick is to set the guage up so you can see it while cranking each time.
(Post 318185)
Thanks you for the time |
Originally Posted by 78montecarlo
(Post 318188)
I going to try that tomorrow, I was thinking if I have to rebuilt the engine ,I just gonna go head and do a swap for a 454 engine . let see what happen .
Thanks you for the time my budy had the hochtkis hit in his car and that if you put a bigblock in it recomends aluminum heads and intake to take a good amount of weight out Hotchkis 89009K Hotchkis TVS Suspension Systems also might want to think about getting a trans |
