6th Gen ('00-'05): My 03 needs new tranny :(
Took my baby to the transmission shop today cause I've been having a pretty bad slip on the 2-3 shift. I was hoping it was nothing too serious, maybe a solenoid or something....turns out I've got some burnt up clutches in there so it's time for a rebuild. I was strongly considering getting rid of it and getting a Charger R/T but we plan on buying a house within the next year so I didn't want to lock myself into such a debt just yet. But as soon as we get our house best believe I will be getting myself a hot rod!
Hopefully the rebuild will be reasonably priced or you could just buy one of these.TEP Transmissions
Tough break Millhouse. If you lived closer to me I would give you my factory tranny for cheep, just sitting in my garage for the last 4 years. Have to chuckle that the allure of a new car with all the new technology does make one take the plunge into debt yet again. Good thing you are exercising restraint....Money money money....
Make sure the shop knows how to actually fix the 4t65e.
There are surefix kits that you can buy to put in these, so when they are rebuilt you aren't having the same problem again in a year or 2.
Also, you could try a transmission cooler install on the next one, should help keep the temps down.
4th is overdrive (we only have 4 forward gears). There is no real answer to your question. If it's starting to slip it's just a matter of time until something gives out. I'd drive it very carefully (don't beat on it at all) until you can get it serviced.
when i first bacame a member here i noticed the problems every one had with there trans i got a trans cooler as soon as possible it runs like it loves it. i hope you will get it fixed properly by a shop that knowes what there doing. when i was in virginia i knew a few really good shops that built trans from the ground up and warrentied them for three years well after the warrenty from the place that sold the parts to make sure if some thing went wrong it got fixed right away with in the three years also if it breaks in the fifth year they fixed it as well. when i got my silverado they fixed the trans after i got it fixed in the fourth year to make sure i will have no problems. it was a type of shop if it was a failure by the reman kit they took care of it if it wasent they charged for anouther kit. it is very hard to find some one who puts there shop name and there rep on the line for there work. i havent found a shop i trust to do a system drain and fill that knowes what there doing other than hay i have tools i am a mechanic. i hope you will have success for getting it fixed and will last for as long as you have it
