Multiple cylinder misfire after washing motor
Old Aug 28, 2014 | 11:03 AM
Jaymoung's Avatar
Default Multiple cylinder misfire after washing motor
I degreased my motor and power washed it at a DIY car wash I've done this before but this time I sprayed the entire motor trying to id a leak afterwards I noticed the car was running rough I figured water affected the cool pack or plugs I throw a "multiple cylinder misfire code" I have not checked and inspected the plugs yet just trying to get other opinions on this.
I'm think new plugs since it's cheap
Old Aug 28, 2014 | 11:23 AM
03SSLE's Avatar
Condensation has probably formed under the boots of the plug wires. Pull the wires (one at a time) and dry the coil and plug ends. Another possibility is that the insulation on the plug wires has fatigued and the water created cross fire between cylinders.
Old Aug 28, 2014 | 11:27 AM
Jaymoung's Avatar
How would you suggest drying them? I don't have a air compressor
05montecarloyo
Aug 8, 2012 07:02 PM
BUDDZZ
Aug 25, 2010 08:16 PM
menaja19
14
Jan 2, 2008 09:21 PM
mloiselle20
May 1, 2007 04:58 PM
