MORE SPEED!
Old May 7, 2007 | 06:45 PM
BuckHunter's Avatar
Default MORE SPEED!
I have a 1999 Z34 3.8 3800 monte carlo i can get my car up to 105 and that is where it cuts out is there anything else i can do to make it go faster i hear u can get 113 out of these cars please post back thanks
Old May 7, 2007 | 07:59 PM
wiz kidd's Avatar
Default RE: MORE SPEED!
high flow cat, no resonator, cold air intake, if there is a u-bend get rid of it
or maybe some computer tuning
Old May 7, 2007 | 11:16 PM
ajsbengals's Avatar
You need to either swap the PCM, or get a tuner for your computer. Accessories wont make a difference for top speed. Its your computer thats stopping at 105. Exhaust and intake mods will most definitly help for 0-60 times and 40-70 times. But top speed is dealt through the computer. Its not a cheap mod though. Atleast 200, some as high as 400
Old May 8, 2007 | 12:17 AM
04 Intimidator's Avatar
Pick up this PCM, it is compatable with your 99 and will remove the top speed limiter. Hookup a with additional mods Wiz mentioned for more power and it will get you to your top end faster. Also make sure your tires are rated for higher speeds. I always get tires at the minimum will do 120 and like getting 140s as they are built with stronger compounds and are more resiliant.
http://www.3800performance.com/Merch...roduct_Count=3
Old May 8, 2007 | 05:24 PM
BuckHunter's Avatar
thanks guys my freinds dad is an auto mechanic so i will see what he can do i will tell u all how it goes
Old May 8, 2007 | 07:09 PM
BuckHunter's Avatar
how hard is this to do
Old May 8, 2007 | 08:25 PM
Once you get at the PCM under the air cleaner it is just a matter of 2 small bolts. The bolts ensure the wireharness stays on... these are like 5 mm bolts or so and easy to get off.
Jul 26, 2008 03:47 PM
02Carlo
Mar 18, 2008 04:17 PM
BeachBumMike
Feb 27, 2008 07:24 PM
BeachBumMike
Aug 14, 2007 09:44 PM
