monte carlo ss 2002
monte carlo ss 2002
can i put a supercharger on a non supercharged monte? and where can i find one? also what kind of performance chip is the best for the 02's oh ya and my oil pressure gause will not work sometimes, any advice on that? thanks
Yes. Lots of threads on that. Dont use a chip they dont work get an actual tune instead from a performance shop. Could just be your gauge cluster is dirty take it out and spray it with compressed air if that doesnt work you got a lose wire somewhere.
Superchargers & Eaton Parts
^^^supercharger kit
^^^supercharger kit
Just do a lot of research before hand and it shouldnt be too hard.
As for the performance chip we really dont use them, we get our pcms tuned by either getting it done in person or buying a canned tune from a 3800 aftermarket company such as ZZP, Intense, W-Body Store, and 3800 Performance.
I really dont know what to tell you about your oil pressure guage, im sure someone with more experience than me will drop in and shed some light...
For the oil gauge, your sensor could be finicky or it's the stepper motor for the gauge itself. The motors are a common problem and cause gauges to fluctuate randomly or just not work. You'll have to remove the cluster and either replace them yourself or send it away to be repaired.
Read This >>>>>https://montecarloforum.com/forum/en.../?ref=esp-link
Also you could try google, Search "top swap" And welcome to the site.
Yes you can put a supercharger on a non-supercharged Monte but some parts are needed. I dont know every part by heart. Some companies have a conversion kit which is a bit pricey but you can use this site as a reference to what is needed in order to get it done. ZZPerformance - L36 Supercharger Kit #ZZ-L36SCK
Also, read this thread about modifying a 3800: https://montecarloforum.com/forum/he...n-3800s-10942/
There is a compression difference, if you are using a non-boosted bottom end you will have higher compression and use boost more effectively. Strength wise? These blocks are solid.
