Monte carlo kinda hesitates when driving slow
Old Sep 28, 2007 | 02:24 PM
04 Intimidator's Avatar
Default RE: Monte carlo kinda hesitates when driving slow
ORIGINAL: menaja19
i looked up the seafoam and they only have it for diesel engine and 4 and 2 cylinder
Otherwise try another cleaner like STP or something you can buy at a local Auto Shop like AutoZone, Advanced Auto Parts, NAPA...
Old Sep 28, 2007 | 02:36 PM
menaja19's Avatar
a fuel injector cleaner correct?
Old Sep 28, 2007 | 02:38 PM
menaja19's Avatar
what is that stuff you selling. i've been looking to get cool stuff done on my car. give me some ideas
Old Sep 30, 2007 | 07:57 PM
06MC's Avatar
Start by cleaning your TB the best way is off the car with TB cleaner but if you are not mechanicly incline than you can by a spray TB cleaner and do it that way, If that doesn't work try cleaning the injectors (not dumping additive in the gas tank) but running cleaning fluid through the injectors thats the only way to clean fuel injectors if they are clogged, The additive in the tank stuff will keep em clean after that.
Old Oct 1, 2007 | 03:33 PM
menaja19's Avatar
kinda silly question but what does TB stands for and what kind of products should i use?
Old Oct 1, 2007 | 03:46 PM
GrandPaDave's Avatar
Throttle Body
Old Oct 2, 2007 | 09:15 PM
06MC's Avatar
ORIGINAL: menaja19
Throttle Body- You can buy any kind of spray TB cleaner as long as it says oxygen sensor safe. Every parts store has it on the shelf I use K&W or CRC. I use it when I clean my air filter(every 8-10K) it's a must for the daily driver with a K&N or any CAI
Old Oct 12, 2007 | 01:02 PM
menaja19's Avatar
how do i clean my throttle body ?
Old Dec 6, 2007 | 10:43 PM
lwilliam's Avatar
there is a technical service bulletin on this. they call it a fishbite hestitation. it says to replace the throttle posistion sensor. has a bad spot inside and the doesn't know how much fuel and timing, etc. to adjust so hince the hesistation
jimbo7
May 30, 2011 03:13 PM
One Dark SS
May 6, 2011 10:19 AM
Bigg J
Nov 14, 2006 03:29 AM
86monte818
Jul 8, 2006 03:20 AM
Eclipse2005
Apr 27, 2006 01:21 PM
