momentary "wheel slip" right after green light
I'm new to the forum and would really appreciate input on a problem I just started to have after taking off the snows:
Upon normal acceleration from a dead stop (such as when the traffic light turns green), the car begins moving normally for about 1 second, then for a very brief period the car behaves as if the front drive wheels slip, and then acceleration resumes normally. This only happens sporadically (once or twice a week). The tires are not slipping but it behaves the same as if I drove over a small ice patch. The lug nuts are tight. I'm hoping it's not some kind of <gulp> transmission slippage problem...
Thanks guys. It's an '03 SS.
May 11: Where did the Mormon ad come from? It wasn't part of my posting (although I'll probably vote for Romney).
Last edited by pushing100; May 11, 2011 at 03:19 AM. Reason: A Mormon ad appeared out of nowhere that's not mine
May be time for a fluid and filter change in the transmission, depending on the mileage since it was last serviced. Does sound like slippage to me. Also, check to make sure it has enough fluid.
I am having a similar issue with my '04 Intimidator ss. Mine seems more frequent, having 106k miles, hard to believe the tranny would be slipping unless the previous owner beat the hell out of it and never changed the fluid/filter. Of course the problem doesn't occur all the time so it's difficult for myself or mechanic to observe any issue.
dez2188
Aug 28, 2013 02:58 PM
Mr.Monte
May 23, 2012 09:06 PM
blackmonte781
Sep 14, 2011 08:46 PM
tyler111991
Apr 11, 2011 11:33 AM
05, 2004, accelerating, carlo, fluid, hesitation, level, momentary, monte, slip, slipping, slips, stop, tranny, transmission
