2nd Gen ('73-'77): Misfire, rough running.
Old Feb 10, 2012 | 08:32 PM
ChadMenke's Avatar
Im just about to start working on the actual block disassembly tonight. Im responding with my DROID from the shop
Old Feb 10, 2012 | 08:51 PM
Zen's Avatar
Zen
What are your plans for it?
Old Feb 10, 2012 | 08:54 PM
ChadMenke's Avatar
For the car in general or the disassembly?
Old Feb 10, 2012 | 08:59 PM
Zen's Avatar
Zen
The engine.I'm always curious when it comes to engines
Old Feb 10, 2012 | 09:03 PM
ChadMenke's Avatar
Im going down to the lower block, so.I.can.check the heads, rocker arms, pistons and bores. Want to be sure it dosent need any machining. I hoping I will find the cause of the smoke from it, or get an idea of why it is
Old Feb 10, 2012 | 09:14 PM
Zen's Avatar
Zen
Should find it then.I think you'll find some leaky valve seals(no biggie to fix)Or maybe some worn out rings.
Do you plan on any performance upgrades?
Old Feb 10, 2012 | 09:17 PM
ChadMenke's Avatar
Im planning on eventually making it a full out street/strip car, but I want to repair the rust damage and get the engine running as close to stock perfect as I can before adding any serious after market upgrades
fiveirontimmy
Mar 3, 2013 02:07 AM
RR CHOPPA
Oct 29, 2010 12:07 AM
mesterx
May 22, 2010 10:05 PM
willysmith
Mar 6, 2007 06:36 PM
robbiegtp
Feb 7, 2007 06:31 PM
