MAP/MAF Sensor for 3.4 motor
Old Apr 22, 2009 | 06:04 PM
sry should have said vacuum not pressure.
On the L67, it actually does both since it has a 2 bar map sensor. L36's and most other cars just use a 1 bar that only reads vac.
i never thought of it like that...using vacuum to measure air intake instead of the other way around.
Yeah, and its suprisingly common. It does make modding a little bit tougher because its relying on the engine's volumetric efficiency values that were pre-entered at the factory. If you have a way to tune the pcm, its fine- but otherwise it can be a pain.
The reason you don't see many people run straight MAP on our cars is because so many people go boosted. The L36 MAP being only a 1 bar can only handle 0 down, the L67 MAP is a 2 bar, so it can do up to about +14.7ish- but a lot of turbo guys go over that. GM does have a 3 bar map also- but the bad thing is you lose resolution the higher you go because you still have the same number of table spots in the pcm- so if you have one sensor reading 0 down vs. another one reading from +29.4 down, you have bigger gaps between where the pcm can read (ie you have bigger steps in your map table).
Old Apr 22, 2009 | 10:53 PM
kweef's Avatar
and with the maf you dont have to rely on set inputs from equations...real time numbers and smaller steps in the table. u really understand your stuff chad.
Old Apr 23, 2009 | 03:58 AM
Thumbs up Thanks
MCF Members `Jeremy & Chad,
Member's: Kweef & Bumpin96Monte
Just wanted to say thanks for sharing your knowledge,
and helping a member.
I keep learning everyday on the MCF, because of
active contributing member's like above.
Old Oct 9, 2009 | 11:31 AM
oh, dont use those modules... Trust Me, it will give you LESS power. i had one from boss performance, supposed to be one of the best ones. needless to say its sitting in my garage with all the other **** i dont use.
Old Oct 9, 2009 | 03:44 PM
MAMONTE's Avatar
And NEVER use Jet Performance products period! They Sucks, and my experience was they ruined my car!
Old Oct 11, 2009 | 04:44 AM
daves92camaro's Avatar
yeah..if you want to though the map sensor..is on the upper intake manifold...right next to the coil packs...in like in front of them...theres a vac. line going into the intake manifold and its a little black rectangle....
vikesfan
Jan 28, 2014 09:32 AM
peteygnyc
Aug 28, 2013 12:23 AM
MJClemm
May 19, 2013 12:01 PM
Dam20735
Sep 7, 2012 01:30 PM
Vladimir
Jun 10, 2009 05:12 PM
