low low idle .. half an rpm
Old Jan 31, 2009 | 04:48 PM
Nova1585's Avatar
Default RE: low low idle .. half an rpm
i would change the battery and the alternator so any of the electrical powering problems are solved and its brand new..
Old Feb 22, 2009 | 11:28 PM
monte07's Avatar
my 07 monte did that as well and found out that my power steering pump and alternator was the culperet first step huck up a volt meter when your car is running it should read at least 14.4 volts no less than 13.8 volts if it reads less it is a alternator problem. how i found out my powerstering pump went bad is when i had it at the shop getting it fixed they put it on the rack rased it seen it before they tutched any thing and said it was a good thing i was heare and they had every thing to fix every thing to fix my problems. the low idel is a good thing. but when stopping and wanting to shut off changeall fileters do maintenence and go from there.it also sounds like a bad fuil filter or a bad plug do the cheapest things first. plugs wires filters oils and if it still does the low idel and want to shut off go after the alternator. what i am saying do the rutene stuff so youll have a peace of mind before youll spend money on the expenceve things
Leprechaun93
Jul 18, 2012 10:39 AM
radiantdragoon87
Aug 16, 2011 10:10 PM
itsjustme
Oct 20, 2010 02:37 PM
AK47
Oct 1, 2010 02:19 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
