6th Gen ('00-'05): Leak
Old May 15, 2014 | 07:53 PM
wesbest's Avatar
Default Leak
I dont know what to call this part so I will describe it. It is the metal housing on the passenger side between the transaxle and the cv shaft and I have a leak between this housing and the transaxle. I would like to know what it is called and any advice about changing the oring or gasket. 4t65e
Old May 15, 2014 | 08:35 PM
turbo monte's Avatar
That would be the diff cover. There is a seal in the diff cover that seals the axle and also a rubber o ring behind that cover. Figure out which spot it's leaking from and go from there. The seal can be changed with the axle pulled and diff cover on. The rubber o ring you need to pull the axle support the trans with a large flat board and a jack and unbolt the diff to engine bracket and then the remaining 2 diff cover bolts. Both take a little time but are fairly easy to do. Anymore questions feel free to ask
Old May 15, 2014 | 08:55 PM
wesbest's Avatar
It's leaking atf that sound right?
Old May 15, 2014 | 08:57 PM
Yes it would leak atf (trans fluid)
Old May 15, 2014 | 09:08 PM
wesbest's Avatar
you're the man buddy
Old May 15, 2014 | 09:26 PM
No problem. Glad to help!
Old May 15, 2014 | 09:51 PM
wesbest's Avatar
how much would a mechanic charge for this?
Old May 15, 2014 | 11:25 PM
I honestly don't know what a mechanic would charge. If you have some tools and an afternoon you could tackle it I'm sure. I could even give you a walk through if needed
Old May 16, 2014 | 11:11 AM
wesbest's Avatar
I can't find the seal and oring to buy to save my life.
Old May 16, 2014 | 11:27 AM
The o ring maybe a hard one to find and is probably gm only. Any parts store will have the axle seal.
