Opinion Needed: L67 Top Swap vs. L36 Bolt-on kit
Many have done this. Me, zippy, maniac just to name a few. There is also write-ups on the forum here of what's needed to be done for it to work correctly.
Reading threw this post I got a lot of info, and some understanding . I have a 2000 MC/SS with the L36. I've been back and fourth on what to do to upgrade my engine. first thought about swapping engine and trans and make it supercharged, because that's what I wanted but couldn't pass up the price I got this for. I have a few issues now,( see why I got it at the price now). Engine has 234,833 on it and I need to replace upper intake do to leak. which lead me to consider top swap, but I also have a trans code p1811 max adapt . not sure if its due to another engine issues .so that got me thinking engine and trans swap. not sure what would be best at this point. I like the idea of top swap but unsure of exactly what it concise of.In need of advice, Trying to make a parts list as well.
Thank you bumpin96monte for your advice and information. and thinking about it. I think its my best option . I think doing so takes care of a lot of issues and I can find a engine with lower miles. Now Is the question as to what engine to choose. A supercharged engine and trans out of a SC/MC if so what year. I think 04-05. or do LS swap if that would work not to sure as to which one.
upper intake swap
Thank you Turbo Monte was going to be my route when I was going to fix my intake issue. now I'm going a new route to all the other issues I have. now choosing the engine and trans to swap and getting a detailed parts list together is next task to see all I'm getting into. this will be my first engine and trans swap.
An LS swap isn't worth it IMO. Easiest LS swap would be an LS4 from a newer monte ss /impala/ gp gxp etc. But from what I've seen, because they were so much more limited, those powertrains seem to go for notably more money. You could easily make up the difference in power with a few bolt ons to the l67/l32 before you drop it back in.
I wouldn't limit yourself to just an l67 from an 04/05 monte. I'd look for any L67 or L32 that had decent mileage as the majority of the engine is generally the same. Certainly a few things might need to be changed around with the throttle body, fuel rail, etc depending what you end up with but that stuff is dirt cheap nowadays.
You are all wrong here.... L67 is the series 2 supercharged engine which is easiest to swap in. L32 is the series 3 supercharged engine which has a tad better supercharger but not really enough to notice in stock form and it's harder to swap in because other components are different.
L36 is series 2 N/A and l26 is series 3 N/A
No doubt you could easily go a lot further on an LS - take the LS4, send it out to ERL for a 6 bolt super deck stroker, add a monster turbo, etc and make well over 1000 whp. Problem is, that'll never hook any gear on a fwd setup, and the transmission will never last without monster investment in custom 1 off parts.
So basically finding a L67 or A L32 and doing a top swap is what you are saying is a good route to go? L67 is the better choice over the L32 even with a top swap rite.
L67 vs L32 is a tough one. The L32 has the slightly better blower and makes a little more power. The L67 will likely be cheaper as there were far more made. Just keep in mind the differences between throttle body actuation (DBW vs DBC) and fueling (return vs returnless) as you will need to convert to match your current setup if needed. I'd go for whatever you find in the best condition with the lowest proven mileage.
https://montecarloforum.com/forum/fw...c-heavy-48949/
