L67 swap in a 02 ss
Old Jun 19, 2012 | 09:13 PM
superss's Avatar
Default L67 swap in a 02 ss
i have a 02 monte ss with 3.8 non s/c im wanting to put a s/c engine and trans into the car . i have a 97 gtp for a doner car. engine,trans wiring,fuel pump ect.I have a few questions is it a bolt in and go and do i have to do anything for my key to work with the s/c pcm ? ps i am new here so any help would be nice thanks
Old Jun 20, 2012 | 08:28 AM
Do you already have the 97? Because I wouldn't use a 97 motor. It's the red-headed stepchild of the L67 world. Most stuff is only compatible with 98+
And you will need a special tune for your PCM using a modified .bin file so your abs and airbags still work.
Old Jun 20, 2012 | 03:55 PM
superss's Avatar
yes i already have the 97 gtp what would i have to do to put just the super charger on the egine i have in the monte now.
Old Jun 20, 2012 | 04:15 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Top swap!
Edit: After looking around for a link for you, it seems that I was wrong. Disregard...
Old Jun 20, 2012 | 06:41 PM
I truly don't know if you can/should do it for a 97 engine. The electronics are also different so your wiring harness might not carry over.
bumpin96monte
47
Jun 20, 2019 10:16 AM
rohanna
Apr 17, 2009 12:17 PM
Cowboy6622
Dec 15, 2007 10:40 AM
chgs15
Feb 2, 2007 05:02 AM
roadshoptuner
Aug 2, 2006 12:53 AM
