Just Got Tuned And Check Engine Light Has New Code
Old Mar 8, 2013 | 02:27 AM
S.O.G.'s Avatar
Question Just Got Tuned And Check Engine Light Has New Code
So I just got my 04ss tuned yesterday and today my check engine light popped up it reads code p0036. anyone have any idea what that code is and how to fix? thanks!
Old Mar 8, 2013 | 08:10 AM
I found this:
Should explain what that code might possibly be!
P0036 Description
Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM).
In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground.The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
Old Mar 8, 2013 | 08:27 AM
Budsjlm's Avatar
Sounds like your front o2 sensor needs replacing
Old Mar 8, 2013 | 10:50 AM
S.O.G.'s Avatar
thanks guys! really appreciate the info!
KWJR86
Jul 12, 2021 12:31 PM
BeachBumMike
Nov 13, 2014 09:28 AM
Enzo354
Nov 29, 2009 12:24 PM
rockieg00
Oct 1, 2009 01:35 PM
Bigg J
May 17, 2007 06:48 PM
