Junkyard find :)
Some honda ricer did a ohm test with a bunch of pepboys and advance brands and found bwd, then bosch to be the best. all others where crap, but he didnt do any msd wires either. Not to take away from msd, alot of people (i have read) had a higher failure rate with any wires other then the oems for any of these engines.
On the MSD website it says that they have the least amount of OHMs of any wire... but then again that could be marketing... Do you by chance have a link to that "ricer ohm test"? I am now very curious, because I just bought my MSD wires and have not had a chance to put them on, I may return them and get others, depending on this test. Thanks
it was for a ricer but wrong car. anyway here it is.
Thanks for posting that, it was very informational. I just wish they would've tested the MSD wires.
I also wish GM would of put the coils on the valve covers on the L67 like the GM LS- series engines. The closer the coils are to the plug, the less resistance. Less resistance= more power
if you have a meter its easy to take a ohm reading. im going to test the ones im throwing in in a bit.
From the factory, GM uses the same ICM and same gauge/type wire (maybe even same length wires) on the L67 and L36, it's the coils that make a slight difference.
I can't say I've ever ohm-ed them out, but I've swapped three cars to L67 coils.
I stand corrected. I don't mind being wrong now and again, at least I learned from it. I like to learn as much as I can about these things. And you were also right, they do use the same length wires for the L67 and L36, cuz when I bought my MSD wires they were the same part number for both. Also if anyone is interested in buying my factory GM L67 coils, they are for sale. Let me know if anyone is interested. Thanks.
The bigger picture is what spark plugs you are running not what coils are on your car. All stock cars are going to have some KR and N/A cars are no exception. Adding a hotter spark is going to do nothing but possibly increase KR not decrease it. I have 4 sets of coils sitting here right now 1 set of L36 2 L67 and these ones from Jegs:
JEGS Performance Products 40122 JEGS GM DIS Coils
None of them make for better throttle response. As far as MSD the coils have been shown to have a high failure rate over stock coils. The best wires for your car are the stock wires but if you want to get some really good wires that are overkill then get wires from here:
Welcome to PRJ.Performance
I am not claiming I am an expert but I think with the stuff I have done to my car and my experience with different parts and mods I know a little about what I am saying.
