Inspection Woes
Old Jul 6, 2020 | 03:58 PM
frankboni's Avatar
Angry Inspection Woes
I have a 2003 SS, with a 3.8 liter engine, and I live in Houston, Tx. I just had a fuel leak repaired, and a new rack and pinion steering system installed. Now I need to get the car inspected, but I can't get the catalyst monitor, and the evaporative system monitor to pass. The car has never had a problem passing an inspection. The inspection people tell me that I need to drive the car a while before the sensors become active. I have driven the car over 300 miles since I had the work was done, and the monitoring machine still shows the catalyst and the evaporative system monitors as incomplete. Everything else checks out. I am told that the engine light would be "on" if the sensors were not working. Please help me with this issue as soon as you can, since my inspection sticker is due by July 31st, and I cannot get it without an official inspection.Thank you.
Old Jul 6, 2020 | 04:16 PM
Not only is 300 miles a requirement, there are a few others to get the drive cycles to repair. But really, 4 drive cycles and 300 miles should do the trick.
But if the lights aren't turning off, there could be an issue with the system itself, get the CEL read if you are showing them and repair the problem. Although if you know a local tuner, they could technically just shut those codes off so that you can pass.
Old Jul 7, 2020 | 08:59 AM
frankboni's Avatar
Thank you ChibiBlackSheep. How/where would I find a local tuner in Houston to shut off the codes?
Old Jul 7, 2020 | 12:25 PM
It's not the most legal thing, so that's why I was saying if you know someone they could. Have you had the CEL read, do you know what your codes are?
Old Jul 7, 2020 | 02:31 PM
frankboni's Avatar
I bought a Seekone SK819 Universal Car Code Reader, and it shows the Catalyst Monitor and the Evaporative System Monitor as incomplete. I do not know how to get the specific codes. Everything else checks out. I also went to this site:https://carfromjapan.com/article/car...tor-not-ready/. I did everything suggested, but the two monitors still show incomplete.
Old Jul 9, 2020 | 10:04 AM
frankboni's Avatar
C'mon, man. I need some help, here. Where can I turn to get some advice?
Old Jul 9, 2020 | 11:41 AM
I don't know what else to tell you. You must have a problem with those systems and need to get them fixed. If you don't have a check engine light on, you will need someone with better technology to help you diagnose.
Old Jul 9, 2020 | 12:37 PM
No offense, but if you need immediate help that must be accurate, a local mechanic shop is your best bet.
Its hard to diagnose electronic issues remotely, especially with the extremely limited information we've got here. Someone needs to plug in a legitimate diagnostic scan tool and figure out what's going on exactly.
This isnt a standard / common problem on these cars, so it's going to be a fairly unique situation.
Old Jul 10, 2020 | 10:31 AM
Scooby doo's Avatar
did the people that installed the rack unplug something and not plug it back in when done?
maybe take it back there and tell them the situation?
sorry new one on me, keep us posted so if anyone else has this problem down the road they can search it and see the answer, good luck.
Old Jul 11, 2020 | 07:25 AM
frankboni's Avatar
Good thought. Unfortunately, I had the starter replaced yesterday, and they disconnected the battery. So I need to start anew to get the odometer where it needs to be. By the way, it was an authorized Chevrolet dealership that performed recall 15V701 and 14V400, and repaired a fuel leak. So I will take it back to them for a look-see. Thanks for the idea. I will let you know what happens.
ang913
May 22, 2012 08:06 AM
May 11, 2012 07:49 AM
Weber's Monte
Apr 15, 2009 04:30 PM
MCking1205
Oct 23, 2007 08:15 PM
