im @ a loss
Old Mar 24, 2011 | 12:56 PM
alkj29's Avatar
Default im @ a loss
I have a 7th gen MC... I recently started experiencing the low oil pressure light coming on, service tms indicator, service air bag (once)..the most annoying right now is low oil pressure..this starts mainly after driving highway speed.. it seems to happen when hits hot after driving a period of time.....Any thoughts.....
Old Mar 24, 2011 | 03:54 PM
Budsjlm's Avatar
did you check your oil level? when is the last time it was changed? what weight are you using? and finialy conventional or synthetic
Old Mar 24, 2011 | 04:16 PM
x2 is your oil level actually low???
You might be having some faulty readings from the BCM just throwing codes at you.
Old Mar 25, 2011 | 12:25 AM
alkj29's Avatar
it acually started almost immediately after getting oil change @ a quick lube joint... about 1500 mi ago.. oil level is fine thats the first thing i checked
Old Mar 25, 2011 | 12:27 AM
alkj29's Avatar
recomended oil and weight right now.. this started after oil change @ a qiuck lube joint..yes lvl is fine
Old Mar 25, 2011 | 09:55 AM
I would go get it changed again somewhere else and see if that helps, if you can't do it yourself.
Old Mar 25, 2011 | 10:24 AM
Cowboy6622's Avatar
Sounds like it is either burning oil or has the wrong weight in it to me. Maybe it has gotten older and needs to use a higher weight, higher mileage oil.
Old Mar 25, 2011 | 04:59 PM
TheMonteMan's Avatar
your supposed to be running 5w30 i dont think its a weight issue. some of the guys i believe on tech had this issue before. i believe it was a sensor. go to ls1tech and do a search in the ls4 section. that is if its an ls4 car.
The Popcorn King
FWD Tech Guides '95-'07
May 26, 2008 06:31 PM
big_mecho13
Feb 14, 2008 08:17 AM
BLACK ATTACK
Jan 1, 2008 05:39 PM
lisacan2
Jan 15, 2007 12:27 AM
Matthew
Jun 19, 2005 03:25 AM
