if my tranny needs replacement. . .
So my cars been stumbling at highway speeds. I'm pretty sure it's the transmissions fault.
I'm going to run some cleaner in the trans, flush and change filter. If it doesn't clear up after that then i'm forced to swap trans. If i do swap, I know of one with a 91k they're are now only asking $250.
I just wanted to know if their is any suggestions of what i should do to the trans before install. Change all sensors in it? any aftermarket pieces i should maybe throw in or anything?
It doesn't sound like this is really a huge issue, the rpms drop a few hundred and thats the only issue? Before you do a trans swap i'd look into solenoids or other possible solutions
I wouldn't settle for the one with 91k on it, that's a lot for a used tranny, i would look for one in the 20k to 50k range or get one rebuilt
What makes you think it's the trans? Lots of potential causes of stumbling at highway speeds. Does it only happen when trans is in overdrive? Have you tried keeping it out of overdrive to see if it still stumbles?
I'd consider letting a shop diagnose the problem before assuming it's the trans.
i know some of the simple of the things will make it stomble like over looking the last time the tune up and fluids have been changed i am not saying the engine oil i am saying the trans fluid as well. also when was the laast time did you clean a reusable air filter or replace the paper one. the maf would be tweeking a few things to save the powertrain. i just want to ask befor doing a computer scan because it will clear it up if it is some thing over looked
Budsjlm
FWD Tech Guides '95-'07
10-29-2015 05:01 PM
killerBee
04-28-2013 03:48 PM
6th Gen ('00-'05): My 03 needs new tranny :(
Milhouse
31
05-31-2012 08:24 AM
slinkeey
02-03-2009 10:33 AM
1998, 2004, 91k, carlo, monte, monter, replacement, replacing, ss, stumble, transmission, transmition
