hunting idle then stall any advice ?
Old Jan 7, 2014 | 06:37 PM
superss's Avatar
Default hunting idle then stall any advice ?
ok forget all the posts that iv put on here in the past since know one knew or didnt know how to help or just didnt want to. but anyway got a o2 mc with l67 complete swap and im having a hunting idle problem and when warm the car will stall but will start right back up. also got a miss fire code p0300 it says bank 1 would this be a o2 sencer , coil pack or a ignition mod. if anybody can help me out that would be cool. the parts that i have changed are plugs,wires,maf,tps vacs line are all good
Old Jan 7, 2014 | 08:35 PM
This may be the obvious, did you get the car retuned for the top swap? If not, that will be important.
If I recall, code P0300 is a "random misfire". Look at things that cause multiple and random cylinders to misfire. Sometimes it boils down to a bad fuel regulator, vac leak, fuel pump, pinched fuel line.....
mZ34c99
Jul 13, 2015 10:30 AM
z34phoenix
Oct 7, 2013 07:42 PM
blownincome
Mar 15, 2010 10:43 PM
Laserblue06ss
Mar 29, 2007 02:49 PM
shawner
Mar 8, 2006 03:27 PM
