How do I check transmission fluid in my '98 Monte Carlo?
Old Jun 2, 2012 | 09:35 AM
alexandryacamille's Avatar
Awaiting Email Confirmation
Default How do I check transmission fluid in my '98 Monte Carlo?
Hi guys! I need some help. I need to put some transmission fluid in my '98 Monte Carlo, but I have no idea how.
Can anyone tell me where the fluid is located in the engine, and how to top it off?
Old Jun 2, 2012 | 09:39 AM
mrl390's Avatar
You fill the transmission through the transmission dip stick. It should be on the back, left hand side of the engine bay. Start the car an take it for a drive until its up to operating temperature. Then park it on a flat surface and check the fluid level on the stick with the engine running. If its low, add it through the dip stick tube using a transmission funnel.
Old Jun 2, 2012 | 09:41 AM
Ah thank you so much!
Old Jun 2, 2012 | 09:42 AM
Also after you add the fluid, slowly shift through all of the gears and then put it back into park before you check again
Jack The Ripper
Mar 31, 2010 01:46 AM
KINGSS
Oct 22, 2009 06:56 PM
KINGSS
Oct 19, 2009 01:40 PM
Frosty LS1
Aug 15, 2009 06:43 PM
jaws2008
Feb 12, 2009 11:21 AM
