6th Gen ('00-'05): How to: Alternator installation
Old Jan 19, 2012 | 11:06 PM
Milhouse's Avatar
Default How to: Alternator installation
I think my alt is going out but I have never replaced one ever, just wondering if you guys know of a how to guide for replacing it? If any of you have ever done it on this car, is it a pretty straight forward thing or something better left to the pro's? I am mechanically inclined, just have no experience with this.
Old Jan 20, 2012 | 07:43 AM
Boxman420's Avatar
it is very easy! i have changed it out 3 times now. there is 2 bolts in the back which are a PITA to get to. i wish i could remember what size they are.. but they are reallly long so just be patient with it. there is also a bolt on the side which is easy to see.. you dont have to take the coolent reservoir out. i did once, but its not necessary. the tensioner is a 1/2in socket just pull up on it once you get the socket it in there and it loosens the belt. i should have done a how to with pictures when i did it the last time..
Old Jan 20, 2012 | 10:52 AM
Enzo354's Avatar
STILL SLOW
Just remember how the belt goes if it falls off. Also be careful of the wires on the back of it. Make sure you un plug all of them first.
Old Jan 20, 2012 | 11:21 AM
forgotten's Avatar
Just go in order, take neg off battery, take off belt, remove the plugs going into alt. Unbolt it. Just do reverse when installing new. Try to tighten the bolts to the same pressure when you took them off.
Old Jan 20, 2012 | 11:23 AM
Alternators are very plug and play. Don't worry about it, just disconnect what you see (3 bolts, belt, plug) and reverse to install.
Old Jan 21, 2012 | 12:10 PM
Milhouse's Avatar
I was able to find a schematic that indicated the rear two bolts and immediately thought "oh boy, that's gonna be fun getting to"
But other than that from what I've been able to find online and what you guys have said here it seems like it's a pretty straight forward deal so I think i'm gonna give it a shot myself.
Old Sep 29, 2012 | 01:47 AM
clement's Avatar
Whoa! Exactly what I'm looking for! Thanks for this guys! I actually need to replace my alternator as it suddenly goes bad yesterday. I'm not that mechanically inclined but I can try doing it myself. Where do you think is the best place to get this automotive car alternator? Thanks!
04MonteLS
Jun 18, 2007 06:01 AM
dponce
Feb 28, 2007 10:12 PM
dponce
Feb 27, 2007 12:54 AM
Danspeed1
Jan 12, 2007 06:34 PM
Boost
Jun 20, 2006 01:20 AM
