hot cranking difficulty
Old Jul 4, 2010 | 05:40 AM
nighthawk626's Avatar
Default hot cranking difficulty
stats
1986 monte ss
350 crate motor
carbureted
problem
early in the morning, the car cranks up at turn key no problems at all.
i turn it off and turn it back on, start no problem.
i turn it off and leave it off from 5minutes-8hours and when i try turning it on within any of that time frame, it literally takes 5-10 seconds to turn over.
if i drive and leave it off for more than 8 hours, it cranks up first time.
so im wondering could this more than likely be distributor problem because i dont feel its the starter, battery, alternator, or carb.
i would appreciate some inputs on this special problem of mine
Old Jul 4, 2010 | 06:33 AM
nemesis's Avatar
2009 Monte Of The Year
did you check the connectors on the battery see if they loose
Old Jul 4, 2010 | 08:34 AM
monte07's Avatar
i would check all the conections leading to the battery to the starter and it also sounds like the starter silinoid. but first thing is first is check the battery to make sure it is giving out the corect cranking amps and voltege. remember you might have voltage and low amps. if the battery is ok it might be two things starter silinoid or the coil that gives the voltage for the distributer. also i forgot to ask when was the last time did you do a tune up as in new plugs and wires?
Old Jul 4, 2010 | 12:44 PM
battery is good. last tune was quite awhile ago. so my next step is distributor coil
Old Jul 12, 2010 | 04:50 PM
monte07's Avatar
did you find out what it was? was it the coil or was it the starter. the reason why i mentioned the starter it could last forever or could be new and go bad. did you find out what it was i am just wondering if you did find out what it was i am glad it is running great
Old Jul 13, 2010 | 06:00 PM
nah man i havent gotten around to it yet. military loves to keep us busy. i should be pulling her out and running by the end of july
Feb 1, 2013 07:35 AM
DTG
Apr 1, 2012 09:02 AM
domesticdisturbance
Aug 21, 2011 11:15 AM
RickCoMatic
Apr 9, 2008 09:22 PM
RickCoMatic
Jan 11, 2008 06:07 PM
