Horses needed
RE: Horses needed
+1 horse for $1600:
http://www.equinenow.com/horse-ad-112670
or if you've got the big bucks:
http://www.equinenow.com/horse-ad-67328
however, you're still only +1 horse power
How many horses were you really needing? Maybe those midget horses can be had for cheaper?
RE: Horses needed
ORIGINAL: bumpin96monte
+1 horse for $1600:
+1 horse for $1600:
Depends on your engine.
If it is a 3400 then swap to a supercharged 3800. If it is a regular 3800, then add turbo.
RE: Horses needed
u.d.p. = under drive pully and they are avalible from mr.Z
headers are avalible for a couple of aftermarket companies a little on the expencif side
cams,throttle body's,3500 intakes and more avalible from ben @ wot tech
RE: Horses needed
IMO, I would be more concerned with upgrading your brakes. If you've got massive wheels like that- its not as big of a deal if you can't accelerate as fast, but not being able to stop nearly as short is a much bigger issue.
