Horses needed
I drive a 2000 LS, What is the best way to get some horse power???
RE: Horses needed
+1 horse for $1600:
http://www.equinenow.com/horse-ad-112670 or if you've got the big bucks: http://www.equinenow.com/horse-ad-67328 however, you're still only +1 horse power How many horses were you really needing? Maybe those midget horses can be had for cheaper? |
RE: Horses needed
ORIGINAL: bumpin96monte +1 horse for $1600: http://www.equinenow.com/horse-ad-112670 or if you've got the big bucks: http://www.equinenow.com/horse-ad-67328 however, you're still only +1 horse power How many horses were you really needing? Maybe those midget horses can be had for cheaper? Depends on your engine. If it is a 3400 then swap to a supercharged 3800. If it is a regular 3800, then add turbo. |
RE: Horses needed
lol bumpin
RE: Horses needed
you can get a cam a set of headers bigget throttle body 3500 uim you can get a u.p.d.
there is plenty you can do what is your buget ? |
RE: Horses needed
just looking to upgrade the horses so i can carry some 22" wheels with ease and still feel the power...
RE: Horses needed
what is all that and which one or combo will give me better performance??? |
RE: Horses needed
u.d.p. = under drive pully and they are avalible from mr.Z
headers are avalible for a couple of aftermarket companies a little on the expencif side cams,throttle body's,3500 intakes and more avalible from ben @ wot tech |
RE: Horses needed
ben @ wot tech?
RE: Horses needed
IMO, I would be more concerned with upgrading your brakes. If you've got massive wheels like that- its not as big of a deal if you can't accelerate as fast, but not being able to stop nearly as short is a much bigger issue.
