Help! - brake job on the Deuce
Old Apr 7, 2012 | 03:32 PM
Default Help! - brake job on the Deuce
My 2006 Monte SS never has had a brake job. I tried today to change them out and put on my drilled and slotted roters
The front calipers are held in place by two bolts. These bolts will not budge. My brother-in-law and I tried heating them, WD40 and a breaker bar on the socket wrench nothing budged them.
Are these bolts maybe reversed threaded?
My brother-in-law will bring over his impact wrench and air compressor tomorrow and we will try that. These calipers never have been off the car.
Any ideas and/or suggestions are appreciated.
Old Apr 7, 2012 | 05:54 PM
Soak them down with PB Blaster penetrating oil. I also usually put the ratchet on and tap on them with a rubber mallet. Most of the time it will break free.
Old Apr 7, 2012 | 07:05 PM
Thank you Lou will get some PB blaster in the morning we where using WD40
Old Apr 7, 2012 | 07:52 PM
I know it took a lot of force to release my '04 bolts last month, first time the calipers have ever been off.
I used a ratchet and sleeved a pipe over it and that did the trick.
If you heat them, if your '06 is like my '04, there are rubber bushings you might damage with heat. Also, I've learned on the rare times I use heat, try heating the head of the bolt. Once heated, let it cool for about 5 minutes then mess with it. By heating the head, the bolt expands a little in whatever it's threaded into. If you try to wrench on it right away, it's the same problem, it's stuck. Let it cool, usually brakes the bold it had and the slight expand/contract makes it easier to work with.
Old Apr 7, 2012 | 10:00 PM
Mike 00LS's Avatar
That's the best thing to do, I had to do that to get the bolts loosened on my seats which are inside, not subjected to weather and to lift my belt tensioner when I changed my serpentine belt. Simple physics, the more leverage you can get the more force is actually applied.
Old Apr 8, 2012 | 07:01 AM
Ya we did use an 18 inch pipe over the reachet. The piston assmbly that inserts into the main part of the caliper had been taken out so the only thing left to take off the rotor is the assembly that actually hold the brake pads. ... I got replacment rubber sleeves for the those retaining bolts too. If we heat again will remember to let the bolts cool down 1st. Maybe we didn't let them cool down enough.
Will try again today hopefully brother in law will be by with his impact ratchet today.
Will also try that PB penetrating oil. Never encountered such a stubborn bolt
Really apprecaite the feed back friends. Tired of seeing the Deuce on jackstands I want to get her out of storage really bad.
Old Apr 8, 2012 | 07:07 AM
Hi `Tadd, I heard the bolts used on your year & model are female Yes, that's what I've heard...They were machined/created to be stubborn
Good Luck on getting yours `Free
  1. How to Remove Stubborn Caliper Bolts | eHow.com
  2. <CITE>eHow | How to Videos, Articles & More - Discover the expert in you. | eHow.comCar Repair & Maintenance</CITE>Cached - Similar
  3. Since there are hundreds of caliper styles and different caliper bolt ... to be confronted with stubborn caliper bolts during a routine brake repair. ... and the right tools are the best ways to free the bolts without breaking them. ... Once the caliper bracket bolts have been removed, pry the caliper assembly off the rotor and bring it ...
  4. How to Take Off Rotors | eHow.com
    Cut from solid steel, a vehicle's brake rotors are designed to withstand a great deal of force. ... If necessary, use an impact driver to break the torque on stubborn bolts. ... For best results, replace the brake pads at the same time as the brake rotor. ... Brick is porous so many products that work on other surfaces will damage<WBR>.
Old Apr 8, 2012 | 07:19 AM
Thanks for the links Space!
Old Apr 8, 2012 | 11:03 AM
Got it off!!!! that PB blaster and the pipe with a ratchet did it!
Hardly needed the hammer either (but I did use it)
Thanks Friends! Drinks on me!!
Old Apr 8, 2012 | 11:21 AM
That is up lifting news!! Hopefully that's the hard part DONE!
I hear ya on wanting to get the Deuce out on the road. My Monte right now is in middle of multiple projects (waiting for some parts to come back to finish the big one). But right now the one I'm not sure I wanted to rip into was changing the evaporator core, but I'm pretty heavy into it and it's a PAIN IMO.
