heater not working correctly
I have a 04 SS 3.8 monte carlo and I'm have troubling with figuring out why the heater isn't working correctly. Last year the heater cord went out and it was replaced. Everything was working fine for the rest of the winter. The weather has changed and I turned my heater on this year and its not blowing hot air. I thought it might be the thermostat but that's working fine. Can you guys give me some ideas as to why its not working correctly?
There could also be an Air pocket in the system....
Or if you didnt do a through flush before you instahled the new heatercore...it could be plugged up again...
R u sure your fluid level in the radiator correct?
Do you have the correct mixture of antifreeze and water?
Are you sure that your system is even flowing (open and closeing of the thermostat)...Is it running hot?...Is the water pump working?
Maybe, Try flushing the system throughly?....
6th Gen ('00-'05): 2003 gas gauge not working correctly
DAVESS2002
Apr 26, 2016 11:52 AM
orthokneepa
Jan 10, 2012 12:11 PM
orthokneepa
Jan 6, 2012 08:56 PM
cornerview
Sep 17, 2010 02:49 AM
