Heater flow control valve???
Old 01-17-2009, 03:45 PM
reevesjo's Avatar
Default Heater flow control valve???
1999 Monte Carlo 3.1. Just replaced the upper & lower intake manifold gaskets and new thermostat. Now the heater is not blowing hot air. Part of the problem was an air lock. Refilled the radiator & reservoir. Better, but not as good as I think it should be. Is this a hot water flow control valve that is mounted on top of the water pump housing. One rubber hose comes "in" and the outlet is a steel tube that goes around the engine into the heater core. There is an adjusting screw?? on the top side. Can I open this a little to improve the flow through the heater core?
[IMG]local://upfiles/2850/E3783B337F55461DB68112930577FE66.jpg[/IMG]
Old 01-17-2009, 06:14 PM
Default RE: Heater flow control valve???
yes that is your bled valve
Old 01-17-2009, 06:17 PM
that is your bleed valve.put a small rag around the housing.then open the screw up untill you see coolant/antifreeze come out.if you do not see ann coolant squeese the radiator hose to ge the air out.good luck dominic
Clarese McConnell
06-27-2013 05:16 AM
ChevySSGirl
04-18-2009 06:42 PM
jdawgkemp
03-26-2009 01:00 AM
js2000mc
10-31-2008 10:37 AM
2000 monte carlo
02-26-2008 09:35 PM
Quick Reply: Heater flow control valve???
