Going Manual
Old Apr 12, 2009 | 07:54 PM
dkunesch's Avatar
Default Going Manual
I am building a 350 for my 86 Monte SS. I want to convert to manual tranny. Does anyone know what transmissions and clutch pedal assemblies will fit?
Old Apr 12, 2009 | 10:53 PM
HI Member:dkunesch, & Welcome to the MCF
You may want to check with companies/sites
like below for a conversion kit for your 86SS.
I am sure they could advise you on the trans &
kit required to complete your conversion.
We hope you take project pic's & post your progress.
Wish you good luck..
Below is for G Body, but it will give you some idea's on
cost & what's in the kit.
New England Monte Carlo SS
Welcome to your #1 Online source for 1978-1988 Monte Carlo, El Camino and Malibu Restoration parts!!
Four-Speed Conversion Kits
Click anywhere on the image to hide it
This is the most complete four-speed transmission conversion kit on the market. Everything needed to change an automatic 1978-�87 G-body vehicle to a manual transmission is included. This is a high quality kit made right here in the good old USA. Laser cut, not stamped, bead blasted and painted with GM restoration black paint. Easy to install and comes with diagram.
DescriptionGM #Part #RetailComplete Kit N/A11-6850$455.00
http://newenglandmontess.com/GM%20restoration.html
Tiderfish
Jan 24, 2007 01:50 PM
fastback4
Jan 19, 2007 07:31 PM
gbergkamp
Oct 30, 2006 07:57 AM
MonteGrrl48174
Oct 23, 2006 10:31 PM
BeachBumMike
Oct 12, 2006 01:45 PM
