fuel injector upgrade?
Old 07-27-2014, 09:28 AM
Yea that's a good question what rockers go with a cam??? Cuz most of time it's either/or
Old 08-02-2014, 10:19 AM
Originally Posted by BrandonStebing
does anyone make aftermarket rocker arms, that CAN be used with an aftermarket cam. i plan to cam my car in the near future before the turbo install
Sure, from one manufacturer or another, you can get ratios from 1.6 (stock) to 1.9.
It's not that you can't do rockers and a cam- you just have to watch your total valve lift. Your heads can only handle so much lift, so on stock heads, you're not going to run a huge cam and the highest ratio rockers together.
The thing with changing lift via rockers- that's a great solution for people who don't want to do a cam (usually because of the labor involved). You don't get all of the benefits of a cam by just doing rockers because you can only adjust one variable (lift). But it is an easy way to add a little power.
Doing a cam and higher ratio rockers on these engines doesn't make any sense. Since you're doing a cam anyways- you should buy the cam that gives the lift you want (you can have just about any spec cam custom ground if you don't like off the shelf grinds).
arent 1.6 ratio the same as stock? what performance gains do you get from the yella terra 1.7?
Yes, 1.6 is roughly stock. However due to flex and the difference in how the tips actuate the valve- stock and aftermarket rockers aren't exactly the same even in 1.6. Also, there is a small loss in friction losses with an aftermarket roller rocker- but the gains to be had with a 1.6 or a 1.7 are nearly nothing.
IMO- if you're doing an aftermarket cam, stick with stock rockers. The money saved can be better spent on the trans, and it's one less potential failure point (look at all of the Harland Sharp failures from the past where the roller ate into the rocker body).
03SSdriver
05-15-2011 11:50 PM
ETexasTwister
07-18-2010 08:33 AM
joesumrall
06-18-2008 08:33 PM
Shasta
11-28-2007 08:29 PM
batman
04-23-2006 09:35 PM
Quick Reply: fuel injector upgrade?
